Yeah unless the block is a 5.3L Vortech block from a late 90's or 2000's vech you can't run the GM factory hydraulic rollers in it, there's no place to bolt the spider down to keep the lifters from rotating in the bores.
I think your best bet is to call Comp Cams or Edelbrock and see what they recommend. They know a lot more about cam seldection then some of the people on this site, myself included.
Personally, I think this cam is pretty wild for a street machine. With that much lift running flat top pistons you might end up having the pistons slap the valves, but they will be able to tell you for sure.
