GhettoRacingKid said:Ahhh. Ur battery got enough juice?
GhettoRacingKid said:From the sounds of it your battery is dead.
Try charging it. Maybe a jump or swap batteries.
jkponce said:I seriously just bought the battery a week ago... I'll try jumping it though... thanks for ur help brother!
crotchss said:Hey just watched your youtube video. I'm thinking the reason you're having a tough time getting it to turn over is the timing. Looking in the video you have the vacuum advance hooked to full time vacuum port. First unhook the distributor line all together from the carb, cap the carb port and set your timing to 14-16* initial or so (it may be off a ways because of the way the advance was hooked up). Adjust your idle speed to where you want it then check the timing again. Moving speed and timing until both are where you want. Then switch the distributor vacuum advance to the timed vacuum port on the front passenger side. In my 20 years of building engines 99% of the time the car runs and behaves better this way(For street driven car). Also when you route your vacuum line make sure that you don't have it laying across the linkage of the carb, just let it hang under it. I saw in your video that the line is laying on the linkage. I've seen guys do this and it gets caught in there under full throttle and holds it open (tends to make an OH sh*t! moment) LOL. I guarantee it will fire up a lot easier hooked this way. As far as the "click" but no start, maybe the starter solenoid has a bad spot in it (could try tapping on it). Either that or you have a bad connection somewhere, check voltage at the starter and check your ground at the block. Also do you have a ground from engine to frame and body? Seen those do weird things too. Hope these ideas help and you get it fixed.
