Hey,
I built this 383 hoping to get the car on the road this past summer but my lack of free time and Honey-Do list have me way behind schedule and we have already had snow here in Central Ontario so realistically I cant see this car leaving my garage until the spring.
The biggest challenge has been trying to stop this oil leak so I wanted to throw what I know at you all to see if anyone has experienced anything similar.
First assembly I used a cheap polished aluminum pan and figured it wasn't sealing properly so I picked up a Moroso pan that was in a clearance bin and used it for the second assembly with a new fel-pro reusable gasket and permatex the right stuff all the way around. After removal and closer inspection the back of the pan seemed like it was out of round. We tried to reshape the pan and re-used the gasket with lots of the right stuff this time. Both times the stuff was spread all the way around not just in the corners.
Still leaking and when I say leaking i mean spraying oil. In ten minutes of running it left a quart of oil on my garage floor.
4th assembly with a brand new moroso pan and a brand new Fel-Pro 1-pc rubber gasket and Permatex Copper in the corners only and a new rear main seal and the thing still leaks.
My engine builder who assembled my short block and I are at a loss.
The plan is to pull the transmission and the flexplate and start the car with someone under it watching.
Until then I thought i would see what people think.
A couple of people have suggested that i may have excessive crank case pressure with the rings not being set yet which is blowing oil out the rear main seal. i have a pcv valve on one cover and an open breather on the other.
Thanks in advance for any comments.
Ill see if i can post some pictures for those who would like to see the car.
