axisg said:any update ?
The update is that it is all together and I have run it for a few short spurts with no leaks.
Well, no Oil leaks. LOL but nothing big.
When I say run it, I mean in my garage on stands or on the ground but I haven't moved it under it's own power.
I put air bags in the rear springs to keep my tires off my fenders and added my rear sway bar from the donor car.
I have the neutral lockout wired for the shifter but still need to do the reverse lights.
It is coming together and I am taking next week off work so I plan to finish it.
Challenges right now are that i am trying to swap my rear bumper for one in better shape but can't get the one off that is on the car now. Bolts are just spinning.
The other challenge that I have is that my mini starter likes to shift so that the starter gear grinds on the ring gear. Starts fine a few times then makes a god awful noise. I have the starter in now with no shims and it seems to be lined up perfectly. (according to my trusty paperclip) The bolts are cranked good and tight but the summit protorque starter comes with bolts that look like regular bolts and i cant find knurled ones like the stock ones in the aftermarket length.
I have lots of bolts and they are grade 8 and 10. Bent the ones that came with it and the current ones are cranked way past spec.
Fingers crossed that they will hold. I may need to fabricate a bracket to hold the starter in place like some of the older motors had.
How about you? Have you pulled the speakers and rebuilt the seat-back?
