crotchss said:If you are running the EGR valve still try capping the port on the carb that leads to it. I have seen these fail before and cause the same symptoms. Just something to check quickly and easily.
I'll try it and see what it does.
johnson350 said:So I haven't really been driving it too much lately, but finally got around to messing with it today.
Well I plugged the egr lines, no difference. Also checked the air horn screws, still tight like they should be.
Took the car out a little today, car seemed to be driving pretty well (except the sticking valve for the lockup torque converter, very annoying while driving in town :evil: ).
Probably drove it for maybe 45 minutes to an hour. Stopped to get gas. Slightly hard to start after filling up, almost as if it was flooded slightly.
Got home and popped the hood to check on everything and noticed a small pool of gasoline sitting in the pockets of the manifold. They were located right underneath the choke thermostat on the carb. Very odd indeed, anyone know what's going on?
Also seemed to use a bit more fuel than it usually does, as in I'm getting awful mileage.
