So I'm looking to pick a few brains here, I'm messing around with the semi-rat 87 442, the car is just a hobby car I've having fun with..
Little back ground when I purchased the car the CEL was on and found no fuse for the ECM in the fuse block. Put in a fuse, CEL went out.
Any ways I'm getting an intermittent CEL at over 50mph ish, when the CEL comes on the TC disengages and fuel economy goes down the tubes. I'm assuming it kicking into limp mode. Slow down to under 40ish, CEL goes out and everything returns to normal. I checked codes with Key On Engine Off by jumping the top 2 terminals on the OBD 1 connector, I got a code 12(its not running anyhow) and a Code 45 Rich Exhaust... I also noticed that I don't hear the MCS clicking with Key On Engine Off... I'm guessing the O2 Sensor has been saturated at this point and should be changed regardless... (only OBD1 scan tool I have is a Bosch it shows no codes and in closed loop gives me some funky readings not sure if its the car.. or the meter)
Should I be thinking bad ECM... or start with O2 sensor and MCS?
