Yours looks high too.I used all Moog parts on my car. I didn't notice a difference. I don't have the engine in the car yet. Is this how yours looks?
The front of your oil pan looks deeper than mine (stock to the crate engine). I think I may be o.k. but thanks for bringing it up. I'll be looking at it. It stinks that the link is different and won't work for you. Are you going to try to source a Delco or GM link?Yours looks high too.
It is a deeper pan. I called the dealer to see if I could get a "GM" one and no luck. For now I've put the old one back on ( it's not loose ) and if I was going to get a replacement, I'd look for an adjustable one.The front of your oil pan looks deeper than mine (stock to the crate engine). I think I may be o.k. but thanks for bringing it up. I'll be looking at it. It stinks that the link is different and won't work for you. Are you going to try to source a Delco or GM link?
What is the distance between the tie rod stud holes on both? OE looks wider tie rod to tie rod.
I'll measure it next time I get it on the hoist.What is the distance between the tie rod stud holes on both? OE looks wider tie rod to tie rod.
