good deal, now vacuum advance... manifold or ported, ive been always told ported, my holley carb has a spot thats for a vacuum advance and its ported.... (if i set the timing at 3000-3500 rpms with the port disconnected n pluged higher then 30 my inital timing is way up there)
this is what my instructions for my distributor said about vacuum advance
"vacuum advance is regulated by manifold vacuum which is a function of
the load placed on the engine. Under light loads, such as when cruising
at a steady speed on the highway, an engine can tolerate more spark
advance than it can when under a heavy load such as when climbing a
hill or accelerating at wide open throttle"
then this is what i found online
"Vacuum canisters control part-throttle timing. By igniting the spark sooner during part-throttle operation, the combustion process is aided. When vacuum canisters first appeared on distributors, the factory designed them to employ a nonadjustable amount of predetermined advance at maximum engine vacuum. As an engine accelerates and vacuum decreases, the canister slowly pulls timing from the engine until it reaches zero vacuum advance. The factory vacuum canisters were designed to work with individual engine combinations. HEI systems were designed to employ less mechanical advance to help control emissions, while point-type distributors featured high amounts of mechanical advance. When engines are altered and modified, their timing demands also change, which is why Crane Cams and Moroso designed adjustable vacuum-advance kits. By simply inserting a 3/32-inch Allen wrench into the end of the canister, the internal vacuum-advance springs can be adjusted to control the engines rate of vacuum advance. The system is also designed to work with a vacuum-timing limiter plate. This plate allows its user to preset the total amount of vacuum timing at maximum engine vacuum."
