I'm trying to get my Ac working on my 1986 El Camino, I've traced the issue down to the control part of it (the part that you change to get vents defrost hot/cold air ect.).
I'm getting:
Thanks in advance.
I'm getting:
- A sucking sound on the right side with the wheel the changes where the vacuum goes
- Defrost is the only setting that's ever on even though other setting are used
- I do get some heat on the floor when driving with the ac on (the ac does blow cold when it needs a few minutes, old car and all that).
- A little bit of air flow when I hold my hand under the thermostat when I had it out last night
Thanks in advance.
