I would suggest getting the correct z-bar for a g body and do you have the correct bellhousing and the special clutch fork?
The pedal stop can be made from a small piece of steel and bolted on. like in the pictures on the link above. I do not think the pedal is that big a deal if you had the right z-bar and rod line it up to the pedal and drill a hole. also look on the link you can judge the distance where the hole needs to be.
Here is another angle
