Thanks. Yes transmission is leaking. I keep an eye on it via a piece of cardboard on the garage floor. There was some oil present in the bellhousing at one point. I dont believe it to be getting on the clutch but i am not certain about that. I will see if it’s still present when i get under the car at some point this weekend. I know I cut a gasket for the input shaft cover. I know it has a drain that should not be covered. I was aware of this at the time. I dont remember all the details on that but was getting conflicting info about it at the time. This was last winter and my memory is a little foggy.I wouldn't think so, unless if the spring you are using is substantially softer than stock. You want to be sure the throwout bearing isn't contacting the pressure plate fingers when the pedal is all the way up or it won't last long. The throwout bearing is meant to "run" only when the pedal is depressed. If it's running all the time, it will wear out very quickly and will start screaming. Then you're pulling the transmission to replace the throwout bearing.
Regarding the leaks....Those old 4-speeds are pretty easy to work on. No internal disassembly is required to address leaks. Make sure your speedometer drive isn't leaking. Beyond that, it's just gaskets and seals. Also thread sealant (not RTV) is advisable on the bolts that go right into the case where the oil is present.
Are you sure it's the transmission that is leaking? Oil on the clutch disk can cause chatter.
Anyhow most of the leaking appears to be coming from a roll pin at the bottom of the transmission. All other bolts i have sealed with aircraft thread sealant. I also replaced tailshaft seal cause it got chewed some how. I had transmission shop “inspect” transmission before install, they said it looked excellent. Knowing i was on a budget he basically just popped the cover and looked inside and said nothing warranted further investigation. If i floor it down a stretch say, i get a good amount of stick vibration. Not sure how much is normal. I know this is antiquated technology and i dont expect it to behave like a Japanese 5 speed but would still like to work out some of the kinks
