1. I have a problem where the carb isn't be adjusted to have a higher idle speed when it is first starting up/when it is cold. (Choke isn't kicking in)
The carburetor is computer controlled and we just replaced it (had to problem on the old one too). I was thinking it probably is the computer, but I thought I would ask you guys if you had any ideas.
2. Also, when you push in the gas at the right amount you can hear a clicking noise and sometimes it just does it without giving it gas. Once you push the pedal down a bit more it goes away. Any ideas?
