The advantages I see are wider side rails, less complex bends on the front rails, and a stock rear frame brace. Downsides I see are the that trans crossmember only bolts to the bottom of the side U channels, a little less boxing in the middle rails, and large openings in the front frame horns. Don't know if the A bodies frames had any add on braces like G body frames have which help.
