What I'm trying to fix is in the ignitions cylinder. I believe some of the spring mechanism that is behind the plastic is broken. I was fortunate enough a few years back while the car was still driving to have someone try and steel it. Right now i wish they had been more successful! It was working until all of a sudden it just all came loose for lack of a better term. With the key in the ignition cylinder it spins freely to the on and start position as if its loose with no resistance or "steps" to each stage like its not connected to anything. I can see (from a hole in the broken column plastic) what looks like a spring which is floating inside so i'm trying to get in there and see what i can do.
So far I'm hung up on rather trivial piece of plastic! Eff me!! It's there right after you remove the steering wheel. I can't figure out how to get it off without breaking it. Then based on some other threads i have found and YouTube i think i can get in there and sort some things out. If someone can help me out for that damn plastic i would be super grateful.
Thank you all
dylan
Thank you all
dylan
