Column swap turn signal switch confusion
12,177
9,796
Here's a few pics of the wiper motor pigtails. I still have to post a pic of the pigtail/ plug coming from the column.
The top two plugs come off the column. Left side is non-delay. Right side is delay. Bottom pic is what the plug looks like head-on.
10,571
14,315
I are a idiot! Just re-read and you did say the turn signals are the problem. DOH! The mechanism inside is the same but I think the later columns used a little extension tab to actuate them. I also think that the turn signal arm pivots on the wiper switch itself. I may be wrong, it's been a while.
12,177
9,796
Mark,
That makes two of us. I didn't bother to study the title or contents of this thread.:doh:just assumed it was a wiper switch compatibility issue....which is not too far from the truth.
Ribbedroof
4,924
7,060
Wellston, OK
FWIW, I swapped an 85 El Camino tilt column into my 81 Malibu wagon that had a standard fixed column. I was able to reuse the 81 turn lever in the 85 column mounted wiper switch. I am still using the dash mounted wiper switch. I had no issues with turn signals, plugged right in and works fine. Perhaps the issue with the turn signals is not in the column, maybe a ground that is loose under dash or somewhere else?
Might also check to make sure that the hazard switch is fully disengaging, if it's a little sticky, signals will not work.
20,397
if you look on the left of the column it should be obvious when it goes, and you just install it with some pressure until it snaps into place
12,177
9,796
I believe you give the stalk a little twist and then pull it out.
