Compressor compatibility
CRAZY TRAIN 86
13
I have a 1986 Buick Regal Limited that came factory with an Oldsmobile 307 & 200-4R transmission & factory A/C. I'm motor swapping it to a modified Buick 455 from a 1976 Buick Electra. I have all the A/C components that came with 1986 Buick Regal minus the compressor. I have the 1976 Buick 455's compressor. The connections at rear of compressor seem like they'll line up. The clutch wiring plug is different but I can modify that. Does anyone know if this will work ? ? ?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
76 came with both style compressors which one do you have?
565bbchevy
9,614
12,683
Michigan
Does it look like this?
Or this?
565bbchevy
9,614
12,683
Michigan
My 86' Regal also came with a 307/200R4 combo and for the AC set up I bought all new components for the factory 307 set up but made brackets to make it work on my 355 SBC, the factory hoses would have worked also but I couldn't get a replacement in time so I just made my own, you could probably do something similar to convert your Olds set up to fit the Buick.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Just a quick search and it looks like one compressor has 2, 5/8 washers and the other has 1, 5/8 and 1, 3/4 inch washer
8,823
7,775
Melville,Saskatchewan
You may need a custom line to tie into the older compressor. Even the V belt and Serpentine R4 compressors are just different enough to need to swap lines, they look quite similar. Basically you need power and ground to the compressor
565bbchevy
9,614
12,683
Michigan
IMO I would just get a new replacement R4 so that you know at least the lines and electrical will be correct, besides I feel the old A6 are too bulky for a Gbody engine compartment.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
May be hard to find the correct brackets for a Buick BB engine
