loudvolvo said:when you say remove the lever and link are you talking bout the linkage down by the trans that, has a spring pressed against the frame rail? The reason i ask is because my camaro was an auto floor shifter and there was and actual cable runner from the shifter. But there was also some other linkage, like some rods. there was also a spring being held against the frame by one of the rods. sorry if thats hard to understand, i dont know nearly as much about trannys as i do motors.
