One more detail. the control arm bushings have a steel insert. The way the bushings are supposed to work is that they are clamped between the frame tabs. Proper set up is to leave them just slightly loose until the car is sitting on the suspension, then torque to spec. This way, the bushings are not 'loaded' when the car is in the 'rest' position. Hard to do on your back, but you can ask the alignment shop to final torque all the bolts when the car is up on the ramp lift/alignment rack.
