A friend and I just installed a Mark VIII fan on his Malibu, and that fan is a BEAST. I'm told it's rated at 5000 CFM, and I believe it. Left running, the 305 never reaches operating temperature, and the fan all but drowns out the sound of the engine.
Luckily, the 454 goes in next week.
Installation Notes:
1. It's not a direct bolt it, but since these cars never came with an electric fan, then none would be. The fabrication is only as tough as you want it to be- meaning it just depends on how good you want it to look. The fan shroud itself is almost exactly the same dimentions as the stock radiator core.
2. 10 gauge power and ground wires, a heavy duty relay, and a 40-45 amp inline fuse are a must. This fan pulls some serious power, do NOT skimp on the wiring unless you want to burn it to the ground. 16-18 gauge wire is adequate for the switch wire, since the relay only pulls a few miliamps to close the circuit. This would apply to any electric fan installation.
3. If you're still running your factory rated alternator, it's time to upgrade. This Malibu for instance is a zero-power option car, and only had a 60 amp alternator. If the fan is pulling 40 amps, that doesn't leave enough to keep the battery charged, especially with the headlights on. A 100 amp alternator was swapped in, and all is well. This also would apply to any electric fan installation.
