Also, I really need better brakes and fast.
OMC, you live in East BeJesus and the track is in West BeJesus. So what's the reason you aren't there regularly????
Too many f*cking projects eating both my time and money. I just finished coaching baseball for the year so I should have more capacity.
Plus, getting this car back together was a huge priority. It's done-ish now... so I can play with a clear conscience.
I just took it for a boot after turning up the duty cycle on the wastegate and got it up to 11psi, then I turned it up some more when I parked it. Hoping for 13psi. It should be tuned a bit better for the track.
The right front tire is kissing the fender liner ever so slightly. Gotta fix that and mount up the drag radials.
You never answered my question about intake temps. Where are they cruising and at 11psi? What meth pump/controller? How much meth volume ya think?
And Hell Yeah! to the drag radials!!!!
Feel lucky
I'm jealous your track actually runs and has T&T events so you don't get shoved in the peon lanes during the 8 kajillion bracket race classes and have zero idea when to run and maybe sneak in 3 passes.
All I want is a 1/4 mile T&T for Saturday or Sunday. Blargh.
My home track used to run 1 T&T focused weekend from May-Sept every month, but that was +10yrs ago and 2 owners ago. The new owner only cares about driftng, they are only running the track at 1/8 mile this year because 'car counts are low' (of course the counts are low when you are never open).
The other track thats somewhat close doesn't have squat scheduled and the only T&T times run 12noon to 7pm on Friday, so you have to take a day off work since nothing is scheduled for the weekend. Lame.
Yeah I'm salty....
Re-test fitting the drag radials. Bit tight. Time to solve for X.
Also, not all 325s are created equal.
The early M&H Racemasters ran a bit narrow for their listed size. They got better in the second release.
I am not ignoring you. I am just swamped jumping from task to task... this is just low on the list.
Quick answer, hardly empirical: But, after heat soaking while I was tuning the VE table it is showing 115-120*F cruising and 120-127*F on a short boosted run to 11 psi. I hope to have better answers tonight.
Looking at the logs it is very very rich... it is probably over meth'd at the moment. It is commanding .741 EQ and is showing around .68 EQ... that is a lot of extra fuel. I want to pull all of that down closer to .780 lambda.
at the orange markers you can see where I assume each stage of the meth is coming on. I need to push the activation leads to HP Tuners so that I can determine exactly when they are coming on. Kind of flying blind at the moment.
