Corvette C6 Wheels
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
one thing I would caution you about is on the rear axle with the 2" adapter that applies extra leverage on the axle especially when cornering. On our G and F body circle track cars we had to run an upgraded right side axle cause with the drastically offset wheel to position the wheel as far out as we could the stock axle would break at the wheel bearing due to the stress
  • Scared
RustBucket
219
60
Houston, TX
What can i do to minimize this hazard? My elco is a 305, wont be racing or burning rubber.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you should be ok if you aren't running it hard around corners but I would keep my eye on the axles. We we mandated to use a Strange axle on the right rear. The rim we used on the right rear and a 2" backspacing
if you ever want to upgrade your rear end a 68-72 Chevelle rear end will fit with the conversion uppers and that rear is 4.5" wider so you wouldn't need spacers.
RustBucket
219
60
Houston, TX
Can't seem to find a chevelle at any yards around here. I just got back from looking at 2 elcos. I want to put ac in my car (I'm in Texas)
I'm Looking to get the brackets for the compressor. Also need that black plastic valve ball that opens my vents.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I just wanted to give you some ideas, it took me almost a year before I found an 8.2 that I was looking for.....it's always better to look for stuff when you don't need it, I was taking it easy on the 7.5 I have in the rear.
RustBucket
219
60
Houston, TX
I have a set of 2" spacers from like 13 years ago when I had 22" blades on another elco. 2" spacers were used in the rear.
would I need a set in the front as well?
pagrunt
9,155
15,321
Elderton, Pa
For pontiacgp's suggestion, besides Chevelles any '68-72 A-body (LeMans/GTO, Cutlass/442, Skylark/GS, '70-'72 Monte Carlo, '69-'72 Grand Prix) will be a source for a rear end.
