So I'm working out the kinks but I'm almost there. I was wondering if my alternator or belt could be causing a rough idle. The red battery light is illuminated and flickers at idle. The battery itself is new and if I drive on the highway for a while the light slowly goes away and the amps climb up closer to where they belong. As of now the amps sit around 11 at start-up I think. It gets worse and goes down if i turn on the heat or headlights too. Could this cause the rough idle? Could it just be a loose belt or is it the alternator? The car drives fine otherwise besides a slight pinging and bogging once warmed up. Could both these issues be related? Any thoughts or help is appreciated.
