Your backup lights and P/neutral safety switch won't work though unless you hook up the linkage from the transmission to the column. The column sleeve is what operates those switches IIRC. I know at one point on my Cutlass way back in the day I had swapped in a column after it got smashed out, and had to swap in the backdrive linkage sleeve with the correct backup light switch(?) and grommet to the column in order to hook it up.
Been a while since I did that so I'm definitely fuzzy on the details. Now that I think about it I could be way off, but I know I did this at one point! (Slept since then!) But unless that sleeve rotates when you shift gears those things (BU lights, P/N safety, dash gear indicator if you've got one) won't work.
If you wanted to just leave the old column and remove the handle, you can use it as a poor man's ignition lockout. Just rotate the column out of P/N and nobody's starting the car!
Also works when converting from auto/column shift to stick
[EDIT: Now that I think about it, I really can't remember why I had to do that in the first place, all the pieces should be there....
must be getting old or something]
