Crank, spark No start/ alternator question
@ck8 and g0thiac Thanks for your help. Just got out here and did the obd1. (I posted it as well maybe may help someone.) So it just kept flashing one....one two at me. I believe this is showing as 12-normal. I'm going to try and test the distributor next and things next.
Yes, I should always flash code 12 three times, then give any other faults. If no codes are stored it just shows 12 continuously.
When you do get it running, if the light comes on then pull the codes in park before you shut it off.
Ok yeah it was continuous 12. You sure are right I will take note of them before shutting it off. I'm looking into the parts now. Hopefully get it going again soon. Thanks alot!
Reactions: g0thiac
