Cutlass taillight repair
I did the LED tape in the 67. I made adapter sockets from bulbs, and soldered phone wire to the filament leads after breaking the glass off. It works ok; I need to revisit my connection method. BUT, when they work, they work great. I did 6 LEDs for tail and 9 for brake/turn in each of the 4 holes. Do your lenses separate easily from the lenses? That would be a huge factor in using my method.
https://www.tapatalk.com/groups/realoldspower/67-led-conversion-t10998.html
Question for you do you think if I used white led rather than red it would be brighter than factory since you said in your thread they are barely brighter only more red?
Also since you seem to have more knowledge than me of wiring what’s the advantage of using an electronic flasher over just using a resistor assuming the resistor is cheaper for hazards and turn signal?
I thought the white would be too pinkish, so that's why I stuck with red. If you want it brighter, just use more LEDs.
I'm not really up on the flasher action; my 67 still has conventional bulbs in the front. I guess it has enough load to work the flasher with theone bulb in th front. Some have an issue with "hyperflash", but I did not.
