Like I said, that basically leaves the pick up coil. They usually fail completely but if the wires have bare spots, it could be grounding out. Use your ohm meter. Measure each wire to the module to ground and the resistance between both wires. Actually it melted around the center contact inside the cap without the ground strap and cooked the coil.
