You could try it, your call. Pick a shop you trust if you have the funds to build it, clutch pack clearance is critical, sure wouldn't hurt. I would do a couple of upgrades. The big Transgo shift kit with billet servo or CK shift kit and servo combo, bottom feed filter, CK has a pan spacer kit to fit the 700R4 filter for use with the stock pan, although a deep pan is better, hardened stator, cheap, stock is weak along with the hardened sun shell, also cheap and the stock one is also weak. Also hardened pump rings and a 10 vane pump with dual slide springs.Those upgrades along with premium clutches and bands should live no problem if everything is right.
