CZF Governor behind an Olds 355
8,827
7,781
You could try it, your call. Pick a shop you trust if you have the funds to build it, clutch pack clearance is critical, sure wouldn't hurt. I would do a couple of upgrades. The big Transgo shift kit with billet servo or CK shift kit and servo combo, bottom feed filter, CK has a pan spacer kit to fit the 700R4 filter for use with the stock pan, although a deep pan is better, hardened stator, cheap, stock is weak along with the hardened sun shell, also cheap and the stock one is also weak. Also hardened pump rings and a 10 vane pump with dual slide springs.Those upgrades along with premium clutches and bands should live no problem if everything is right.
oldson
48
Cool! Thanks Olds307. Haven't decided yet on whether to attempt myself or just have it done. Got a price tonight so, gotta see what parts cost and go from there.
TexasT
411
94
Texas
if you send it out, make sure the builder has a track record with 2004r. The local guy who does "race" transmissions rarely knows anything about a good shifting 2004r.
If you decide you want to give it a try hit v8rumbles thread on his overhaul. Lots of us have assembled our own. It isn't near as hard and the pros would make it seem.
Let us know, i'm glad to answer questions as best I can.
TRX
31
4
Central Arkansas
JAny one tackle a rebuild by themselves or would I be better off handing it to a pro
Buy the ATRA manual and look through it. Ron Sessions' T350 rebuild book has some useful workaround for improvising clutch pack compressors, etc. that might prove useful even though it's for a different transmission. Besides compressors, you'll need feeler gauges, a dial indicator and stand to check end play, a rubber-tipped air nozzle to check clutch pack operation, a compressor or air tank, a slide hammer and piece of angle iron to remove the front pump, and a bushing driver kit. Plus some dental picks and odds and ends...
Figure up the tools you'll need. You need a clean place to work; I use a hollow core door across sawhorses and cover it with newspaper. Take LOTS of photos. Bag each subassembly in plastic grocery bags and sandwich bags. Clean the case first, then clean and rebuild each subassembly and install them.
If you're changing all the bushings, select-fitting steels and frictions (thickness varies according to manufacturer), shimming proper end play, etc., it can take a while. But it's not rocket surgery, and once you have the tools and a build under your belt, the next time is almost a no-brainer.
Here's a page I made about building a T350: http://dave2.freeshell.org/car1/TWtrans/twtrans.htm The 200 is more complicated, but it's "more of the same", not radically different.
20,397
Actually the Monte SS came with 3:42's, and the 442's came with 3:73's. Learned this last year when I was lucky enough to find an '85 442 in the wreckers with the 8.5".
Either way, the governors should be close enough between the two not to make much of a difference. I pulled the matching 200R4 out of the same 442, and it'll shift at 5500 rpm at WOT with the upgraded governor from the TransGo stage II shift kit I installed in it.
Just FWIW.
The Monte SS changed to 3:73 in 85
oldson
48
Ok y'all, I have an update and a coupla questions. I was scanning CL and I found a 2004r that was rebuilt with a 3K stall and a TSI constant pressure VB. I was told that it was behind a 377 and was built to handle 725 HP. I went to look at it and a quick visual showed new seals, repainted, and a hardened stator. I called the guy who built it prior to meeting and asked what a basic rebuild takes. He told me he automatically puts in the hardened parts and then works with the customer from there. I was comfy with it as it looked like it only had 2K miles since rebuild and it was less then a rebuild of mine so, I bought it.
Just to refresh, I'm putting this behind a mild olds 355 and out put will go to a 3.42 8.5 rear.
So here are my questions:
1) anyone have experience with a constant pressure VB?
2) would it be wise to go to a lower stall? (I was told it shifts normally around town, but at WOT it's about 5800)
3) It's an '85 CR code trans (any issues with it vs. an '87 CZF even though it was rebuilt?)
I do have an '87 CZF coded trans that I can get the governor and, if need be, the VB if I am so inclined.
Any input would be appreciated.
thanks
8,827
7,781
If it is a quality 3K converter it should drive OK around town but a 2200ish stall would be better. The constant pressure valve body is supposed to eliminate any burning of the clutches from an improper TV adjustment.
oldson
48
Thanks Olds307. That's what I was thinking. I was going to get a lower stall and then drive it for a bit and see how it is.
