A little frustrated and upset with what was going on, I made a decision to get serious with the car and make it right. I pulled the engine and and began trying to diagnose my low oil pressure issues.
Each part cleaned and inspected. I measured the rods and main caps, all within specs. Bearings were worn, but not excessively. The crankshaft look great, but once on the mic it was a different story. The main journals were measuring up to .060" under sized for a total clearance of almost .100". Well there's your problem!
After making some calls and doing some research, I elected to purchase a new crankshaft for the awesome price of just over $300 through a local performance parts supplier.
I saved my $ and was able to round up a few more goodies to breath some life into this tired engine.
The list included a new high volume oil pump, 7 quart oil pan with matching pick-up, high flow fuel pump, new valve covers and air cleaner housing, new bearings, a Summit version of the Edelbrock camshaft and of course new gaskets. I was also able to pickup an Edelbrock water pump as a local swap meet to finish it all off.
Back together and ready to drop back into the car I made a discovery that I want you all to pay attention too. This is the flexplate I had been running on my BBC since day one of the first build, it came with the first engine.
IT DOES NOT HAVE A COUNTER WEIGHT! OOPS!
I researched and sourced a used flexplate and confirmed I had the correct damper on the front.
Running the wrong flexplate will cause premature crankshaft & bearing wear. It also cause a slight annoying vibration. Sounds familiar and is the reason I am on round 3 of 454 builds. I wont be doing that again!
The heart of the beast was once again up and running. Smooth as silk, sounding mean and with tons of oil pressure!
