X2 its a lot of wires being held onto the back of the dash with little wire clips. The first time I was careful & removed each screw holding the clip which was a pain in the a$$ & took forever. Th second, third & forth time I took a dash out I just broke the clips & had the dash out in 15 minutes maxkuruption109 said:4 bolts up top 7mm and 3 on the bottom 10mm.. plus the wires have to be unhooked which is the pain in the @$$ of the whole process.. otherwise its easy!! ive been meaning to make a how to vid on that @ the junk yard
Wow! Never knew thatBlake442 said:Unbolt the fuse block and all the wires come out with the dash...
