Dash ligh work sometimes?
Isn't there more then one dash light bulb??
theres about 12 or so lights in your dash that all should run through a printed circuit board, maybe theres a really badly burnt bulb that only makes contact sometimes, maybe even shorting out the rest of the lights. also when your in there (lightly) tighten the bolts that hold the circuit board down, they're notorious for coming loose ( you can see in my pics i had to do this to mine). alarms are also bad for screwing up wiring tho...
i couldnt find the pictures you were talking about and ill have to take a look at it this weekend they came back on, on my way home from work they dont really flicker on they turn on like they would if i pulled the headlight switch to turn on my lights and the alarm was on there when i got the car it was installed at car toys so i dont think they messed i up to bad
its usually the alarm itself, rather than the install. ive had 2 vehicles already that i couldnt get running until i disconnected the alarms (which were installed properly)
