My dash light flash on and off sometimes when I brake and drive . Does anybody know if this is a ground problem if so where is it located ? I swap all the lights to new leds a year ago
I bought over 3 dimmer switch two of the times they sold me bad switchesCould be a dead spot in the dimmer, too. Turn the headlight switch knob to see if it changes; I had the same problem on mine. New headlight switch will fix it if that's the problem.
Also how long does them bulbs usually last?Sometimes led bulbs failing can cause weird stuff.
* instrument panel dimmer NOT high/low headlight dimmer. They're different- one on top of the column, one is the front section of the headlight switch.I bought over 3 dimmer switch two of the times they sold me bad switches
That might be the problem
* instrument panel dimmer NOT high/low headlight dimmer. They're different- one on top of the column, one is the front section of the headlight switch.[/QUOTE
Does anyone know where to find a instrument panel switch ? No one lists one, even rock auto. 86 olds cutlass
