OK. I just went down the basement and found my 81' harness. Lucky for you, the wiring looks the same. Black,pink,grey,purple, and green if you have it, is for the pulse wipers. Of course the connector is different but that's not hard to get. So when your column comes, there should be a small harness coming out alongside the main big one,they both snake down the column cover. It has a wide 5 pin connector. There will be black,pink,grey, purple, and green for pulse which the new one probably has. If your column comes with pulse wipers, and the car doesn't, be aware that you need to change to non pulse switch, or change the motor assembly to pulse to work correctly. They may work, I'm not sure, but you definitely can't have pulse without both components. Either find the correct connector and wire your old harness up to it, or change over to an aftermarket connector and you're done. I was too lazy to do that so I used the AC duct in the upper left hand corner my 86' SS dash to mount the old dash switch into. It looked OK but I'm easilly amused anyway.
