That's why I used the AC duct in the upper left corner of the SS pod. It's easilly popped out and an AC louver put back in if needed (My Malibu had no AC). I just epoxied the old dash switch right in, but rotated 90 degrees. Fugly but functional. The wiper swap is actaully very easy. Pulse wiper switches use a 5 wire harness and the green wire is the pulse. The wiper motor has the circuitry for the pulse function so you must use the right one. It goes for about $80 at Rockauto rebuilt. The switch on the column goes for around $110 new so don't break one! A non pulse wiper system uses only four wires and GM maintains it's color coding-black,grey,pink,purple. My 83' Bonneville had the 5 wire connector in the factory harness with the 5th (green) wire already in there and the connector on the non pulse wiper motor had the 5th wire (green) in it as well. So it was a simple matter of useing a pulse wiper motor and a pulse column switch that plugged right in to the cars wiring which was there waiting for it. GM figured why make 2 harnesses, just include the optional wires. If your car did not have the pulse option available you would then need to add the green wire that goes from the column switch connector all the way to the wiper motor connector. The hardest part of all this is if you need to change the switch in the column then the whole freakin thing needs to be opened up and it's a bitchy job. On my car the switch was bad and just to pass inspection and be safe I replaced it. I wasn't about to pay $110 and open it again so I got a tilt column with pulse switch for $50, much easier.
