I'm leaning toward changing the lifters then. If it were the rockers what are the odds I'd hear it from both sides at a particular time into idle. Thanks for the suggestiins.I used to run Rhoads lifters in my circle track car back in the day to reduce the duration slightly to meet the vacuum rule. With mufflers on you could hear the lifters ticking at low RPM but once it got above maybe 2500 RPM it went away. This is the way they sound because they are bleeding off oil inside the lifter to make the cam seem smaller down low.
