In August 2017, I installed a TrueTrac into my 8.8 axle. Since that time, it has turned both rear tires every time I hit the throttle, even with one tire on gravel and the other on dry pavement. At the same time, when not under hard acceleration the differential is completely smooth and quiet. Off the throttle, it sounds and behaves just like an open differential; get on the gas and it instantly behaves like a spool.
I love it, and I could not recommend a limited slip more highly than this.
Do you think it would be the same with a 7.5"
I dont plan on pushing more than 350hp 350tq anytime in the near future (if ever). Im just worried about it being quiet and functional.
There are the Auburn Style Kits on Ebay (Carrier, Ring/Pinion, Rebuild Kit, Bearings) for about as much as a TruTrac.
I'm on the fence..
Its either spending a lot more on the 7.5 getting a TrueTrac, OR one of those kits for the 7.5 behind the 305 for now, and if the 305 ever goes t*ts up and I go with the 6.6L 400 Poncho Plan, switch rear ends to something more stout..
-Gonz
