Must have been the final years of it. Never seen one. Camaro/ Firebirds yesNo, TBI was only available on V6 engines for G bodies.
Probably why I never saw them. Most of the ones I saw were Buick power. By then the front wheel drive cars were popping radiators left and right. I ran a radiator shop up until 95’. Sold the shop to my brother and he still has some of the ANOS heater cores and radiators for GM, Ford and some foreign cars. He’s a Mopar nut so all those he sold.In the last couple of years the base V6s for Monte Carlos switched to TBI. However, the base Buick V6s remained with CCC Dualjet carbs until the end of G body production.
So I replaced the ignition coil which didn't solve the issue. I don't want to keep throwing money at the problem, so before I replace the ignition module, I'll check the fuel filter; how do I check to see that I am getting fuel and how do I check the fuel pump?I know everyone is pointing at the coil and such but did you check to see if your getting fuel? Or a plugged fuel filter/ pump?
Checking the fuel pump on a non-running engine is a literal crapshoot.So I replaced the ignition coil which didn't solve the issue. I don't want to keep throwing money at the problem, so before I replace the ignition module, I'll check the fuel filter; how do I check to see that I am getting fuel and how do I check the fuel pump?
PS- yes, it's the Qjet carb which I rebuilt a couple years ago. The CCC system is all there and working, or at least has been until this came up.
Before you changed the coil, did you verify that you had no spark? Without knowing that you had a no spark condition, you rolled the dice and changed the coil. At this point, do you still have a no spark condition or not?Should've said this in my post^^^when it rears it's ugly head, that's the time to troubleshoot. Agreed don't dismiss that it could be fuel but that's why we troubleshoot.
