Alright some of you may have read my recent thread about trans issues but I have stumbled across another issue and I figured since it may potentially help others with similar problems I'll make another thread.
My problem is a vibration occurring under throttle above about 2k rpm regardless of gear or temp. It does it in park and driving down the road. No abnormal noises, oil pressure is good and no other symptoms of engine failure. Car has a big block with solid engine, body mounts and rubber trans mounts if it matters. Any idea on what could be the culprit? It did it with the old converter as well and when I replaced it I made sure flex plate bolts were tight. If anyone could help me diagnose this I will buy u a cyber beer for your troubles! Thanks guys.
