Yeah, the 2.29 gears suck *ss. You probably have a TH350C. You need a TH2004R overdrive, a junkyard trans with a Transgo shift kit should be plenty. Definitely don't use the green line bias spring in the kit, raises full throttle shift points. Factory most 2004R's shift at 3000 to 4000 rpm full throttle, what is the diesel's redline? Add a 3.42 gear, TCI gear calculator to figure out which speedo gears are needed. Your highway rpm will stay the same with overdrive but your acceleration will improve a lot. Why they equipped them with the 3spd with super tall gears is beyond me, it made them feel even more gutless. Between more air in, headers with duals and better gearing it will be much better in every way. Plus mileage might actually improve.
