differences between 81 and 82 7.5 rear
jcelk
337
255
i think the carrier bearings are larger on the 82 and up how can i tell the difference with out tearing the rear apart
Reactions: Sweet_Johnny
if the carrier bearings are larger/smaller, I would suspect that it has to be Series I vs Series II carrier. or to put it a different way, where the gear ratio breaks and requires a different thickness ring gear to the pinion. I believe that is around 3.20:1
