Just got my 383 stroker running in my 80 Malibu and trying to work out some kinks. The biggest issue is with the distributor. Motor has a Lunati 60103 cam with a Summit Racing HEI distributor. Set the timing and noticed that every time we try and start the motor it pushes up on the distributor which throws it out of time (with the clamp loose). The problem is, once we tighten the clamp and drive the car for a little while the clamp comes loose and obviously throws the motor out of time. The distributor doesnt seem to come up once the motor is running, only when it is started. I thought maybe the vibrations may be loosening the clamp bolt, but I would think other things would be loose as well. Dont really know too much about this. This is my first project so I am kind of learning as I go. Any help is appreciated .
