Well, had a little success today. The last two motors I've had on order finally arrived. Hooked them up and jogged the machine on all axis. Everything appeared to work fine so I loaded some G-code and hit run. The machine took over and began cutting away.
It cut "something" but wasn't exactly what I had drawn. Lol Everything seemed to be cut at half scale. I still need to calibrate the machine so that if the machine moves 40" then the software should also say it moved 40". That may be part of the problem.
