Do these things work?
Bonnewagon
Lost in the Labyrinth
10,564
14,298
Queens, NY
I just went through a horrible job swapping out a transmission shifter cable on my Sunfire. While looking for parts I saw that they offer a kit of new plastic retainers that repair the cable end without going through the hell I just went through. I also saw that many GM vehicles like Yukons use these same type cables. Has anyone used them? Here are a few pics, one of the broken ends, a good end, and the kit of new retainers. I read they can be tough to install, but do-able and well worth it. What do you think? IMG_0691.JPG IMG_0690.JPG kit.jpg
SS_Malibu
1,171
2,051
Mesa, AZ
I've used those inserts on my cavalier. Yes, they worked quite well. I was very pleased with them. Swapping the cable out would have been a complete pain in the azz. As it sounds like you know all to well.
black_aerocoupe
106
46
I used aftermarket bushing(s) at the shift lever end of the shift cable on a 6L80 truck.
With a new GM lever (integral ballstud,) the aftermarket bushings failed to keep the cable retained.
The ballstud is no gem. I removed it. Turned and threaded a bolt. Pressed the bolt into the lever to replace the ballstud. Turned a bushing to fit. And now have a double nutted retention of my shift cable now.
I like the idea of easy assembly. But when leverage causes something with wear to pop off readily, it's a poor design.
