Door Sill Floor Pan Metal
john87442
316
369
Geneva ohio
Looks very good! I recently had to do the same thing, it’s a shame they don’t make a replacement piece for this but it wasn’t as difficult as I thought it would be. The hard part was was the separate piece under this side rail that has the threaded hole for the seat belt had to be removed also and then after I bent and welded the new rail piece, it had to be correctly located and welded in also.
john87442
316
369
Geneva ohio
This might be hard to understand but this is the piece under the side rail that houses the number three body mount z bolt cage and the threaded spot for the seat belt. When the rusted rail is cut out this piece is also welded to the inner rocker and needs possibly to be addressed.
Hurricane77
333
677
Ottawa, Canada
On the later model cars, yes, that's all one piece. On earlier models the body mount cage is a much smaller piece and doesn't incorporate the seatbelt mount. The seatbelt mount there is just a reinforcing plate with a nut - pretty much exactly the same as how the rear seatbelts mount or the front seatbelt mounts on the tunnel.
Not sure where they made the change, I'm assuming between the 80 and 81 model years.
CopperNick
3,376
3,035
Canada
My Monte is an 85. it has the outer re-inforcing plates for the shoulder harness and inner rr-inforcing plates for the tunnel straps. Underneath the strap located there goes between the front inner/tunnel side seat mounts and acts as sort of a driveshaft loop.
