Today went better, Wife is in bad mood, sh*t breaking and snarky comments from a member here makes me grouchy as well. I finally got the old boost valve out and used a hand file to clean out any burrs. I wish the bigger low/reverse boost valve didn't get damaged. I used the small stock low/reverse valve, .555" is wrecked so a .500" foward boost valve and stiffer spring. I also tried the new Permatex Optimum Black RTV supposedly 15% more oil resistance and 40% stronger than Ultra Black. It actually suggests a trans pan as a use, so I glued the fiber pan on the pan side and torqued down to flatten the gasket out. I got everything else off. I even pulled the pan and oil pump so I don't have to take off the hood. I also tapped out the new dipstick tube from Supercars Unlimited so it doesn't get broken pulling it. I will get the Daughter's boyfriend to pull the 88 out of the way when I lift the engine. I think it will be my winter weight in the Dakota.
