Well this 350 has been running good except hot restarts, think I have the choke close to right, could be heat soak. The choke is fully opening and it takes a long crank and sometimes holding the gas pedal to the floor. I am running two thin Mr Gasket 4 hole carb base gaskets, both very thin on an iron manifold. I have the 4 hole phenolic 1" spacer that goes with the gasket, I just need longer bolts. I may notch the Metric thread mixture screws, can't find the proper head for my carb adjustment tool, they may be out of adjustment.
