So, I used to have a TCI Fast Gate shifter on this car. One thing that annoyed me was the reverse lock out needed to be pulled up and down to work. So after I took it off, I added a spring. The release lever now works as it should. Why they don't they put in a 5 cent spring is beyond me. Part of the reason for the swap isn't just manual shifting fun. For some reason, ever since I put back in the stock column parts, I can barely get Park if want manual Low gear. So unless I push the lever hard on the column, the park pawl doesn't engage. Even then, I get in the car after work, my fat *ss will make the pawl slip a notch. Weird that factory parts won't work right, no matter the adjustment. The only thing it won't have, unless I find the wires and figure out where to get the micro switch in the right place, is the reverse lights. I plan to lock the column in Park. I need to put it in this weekend and fix the oil leak on the aftermarket gauge, pretty sure it is the 1/8" adapter, which I can't find anywhere. I actually used a piece off a metal air gun. It might be JB weld or Permatex Cold Weld, depending what I find around my place. It is a small leak.
