It maybe time for the permit stuff. Just wary of the stuff that needs a hot wrench for removal. What is the set time on the permanent stuff?Red Locktite!
Wow my B body only get 18.8 with efi at 70mph Must have something to do with the aero dynamicsWell a great 5 hour round trip, 430 km. The 88 performed flawlessly, 165 to 180 temp, 45 psi steady cruising oil pressure at a steady 65 to 68 mph, around 2000 rpm. My Optimum Grey fix on the cruise servo fixed it, now rock steady, no more surging up and down. The best part, 24 mpg Imperial. I could probably knock down 25 mpg just by doing 60 mph. Somehow my speedometer is only 1 or 2 mph fast comparing against my gps speedo app, thought it was off by 5 mph. Just a great cruising car, used nothing as far as oil, trans or antifreeze.
Remember it is imperial mpg, so similar to your car 20 US mpg and this car is no lightweight, close to 4000 pounds with me and all the spare parts, including 2 tires and rims in the trunk. Honestly, within 2 mpg of the 260 with way more power is awesome. Ironically the 307 Qjet got worse mpg than this custom Qjet on this motor like 4 mpg. Also worse on the other 350. Of course being able to adjust the APT helps mpg, lean it out in 2 seconds. I plan on doing a compression test on this 350 tomorrow.Wow my B body only get 18.8 with efi at 70mph Must have something to do with the aero dynamics
Keep cruising
