whats up fellow gear heads, I have an 86 el camino/caballero, last year i did an ls swap with a 4l60E I used the stock placement for the transmission cross member with the stock driveshaft and all was fine, I just recently upgraded to 373 gears and upgraded the u-joints when putting the drive line back in, last weekend while releasing some stress/testing out the new gears on the frwy, my drive line decided to eject itself from car, the weird part is, i didnt get any warnings before, no wobble noise or rough riding, it just shot out like a rocket. that being said does anyone know what could have gone wrong and does anyone know if can pull one out of a newer model car or do i need a custom made driveshaft seeing how these are discontinued anything helps!
P.S. the bad news for you guys is, theres no damaged pictures for you to see! the good news is, theres no damaged pictures for you too see 😂
