Driveshaft length
cycomiko
27
6
My stock 7.5 driveshaft is about 52 1/2 from u-joint to u-joint. Does 51 1/2 sound correct for a 8.5 rear upgrade.
85GPLef41
2,210
159
Colorado
Sounds about right.... best way to make sure is raise the car up on jackstands and with the weight of the car on the rear axle, install the drive shaft in the trans and measure from center of the front u joint to rear u joint. I did the same and but can't seem to remember the exact measurements... :| but It worked out great!
don4life
Jun 22, 2014
76
2
i read some where that the 8.5 drive shaft was an inch shorter than the 7.5 but could be wrong
cycomiko
27
6
How much should I pull out the yoke in the trans before I measure. I've been told to insert the yoke all the way and then pull out about 1/4 of an inch. Someone else suggested to do it 1 inch. What should I do?
20,397
If you are using a drive shaft you used with 7.5 rear there is no need to try to figure out what length you need. The drive shaft for 8.5 rear is one inch shorter
